If The bearing and spindle is new should have a SLIP FIT of .0015 (1 1/2 thousands), anything more than .005 (5 thousands) will cause galling/grooving to the spindle's surface, sleeves are available to repair worn spindles, but that will require machining,... new/ good used spindles are a much more viable alternative
