A good time/place to ask this question ...
What do you use on the inside of the pan - just the pickup block ???
I smear a coating of the "Right Stuff" on the pickup block were it pulls against the pan, then a I also smear some on the threads of the fitting that screw in the block.
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
