Quote: I think there talking about the old trick of shimming the side gears into the spiders on an open diff. It would create enough bind to actually mimic a sure-grip to a degree. Would also wear very fast.
actually, its preloading the pass rear with a air shock. nice trick, works well.
how do you get an air shock inside the diff housing ???
