I've tried Body Schutz & it is fairly heavy build, but smoother & not as thick as the OE stuff. There's NO WAY you can get the heavy buildup like the factory stuff (1/4" thick?) out of a spray can or conventional sprayers. There's 2 things almost impossible to duplicate to the factory: thickness & texture. That's why I'm hoping the Rhino bedliner spray-on route.
I'm going with black, just like factory. He!!, I'd like to do this in white on my basement walls too. It would look good plus it would be a good Radon barrier & insulator. I wonder if it would adhere well to concrete? It would be very expensive I would guess, plus I don't know if they could do it portable???
