Quote: Thanks for the help, but I may have stumbled upon the real problem.....from another post on this blog----it would involve the Edelbrock 750cfm carb #1411......according to the other blog---this carb SUCKS!!!! is this true????
451 C.I. (400 block 440 crank) 750 cfm edelbrock (1411) No Problem with this carb... 22 inch rad, shroud,Mopar cluthfan Milodon high volume water pump and use more water instead of antifreeze if you don't use your car during cold weather... I use 90% Water 10% Antifreeze + 1 bottle of Waterwetter Never had Overheating Problem
