I'm starting out with 2 new gear this year.
Both are race only.
8 3/4 4.30 US Gear with spool in 742 case
Dana 60 4.56 Richmond Pro gears
I've never replaced the lube in the past but I've seen some posts that suggest that I should.
Do you think it's necessary?
If so, could I just suck out some out of the bottom and just replace it.
Or is it a waste of time and money?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
