Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons
[Re: wayfarer1]
#63491
05/26/08 08:56 PM
05/26/08 08:56 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
So if I use the BBP disc brakes I have with the 73 spool k-member I should be good?
I have to get the old motor out first and evaluate the condition of the original k-frame before I make a final decision on replacing it.
Thanks for the info! Joe
Yes, that will be fine. If have to, you can re-use your 72 biscuit type K-member too.
Do any of these setups have lower control arms with sway bars tabs??
The one on the left is a 73-76. The one of the right is a 67-72
Entire Thread
wayfarer1
05/26/08 01:12 AM
jmf340
05/26/08 01:43 AM
05/26/08 01:46 AM
autoxcuda
05/26/08 02:16 AM
patrick
05/26/08 12:04 PM
RokketRide
05/26/08 06:24 PM
autoxcuda
05/26/08 07:15 PM
wayfarer1
05/27/08 12:26 AM
autoxcuda
05/27/08 12:56 AM
wayfarer1
05/27/08 01:13 PM
boden
05/29/08 01:47 AM
65cuda
05/29/08 02:04 AM
Rug_Trucker
05/29/08 02:17 AM
48Heap
05/29/08 07:37 PM
klunick
05/29/08 09:08 PM
RokketRide
05/29/08 03:14 AM
wayfarer1
05/29/08 04:21 AM
65cuda
05/29/08 04:34 AM
autoxcuda
05/29/08 04:45 AM
RokketRide
05/29/08 04:50 AM
autoxcuda
05/29/08 05:56 AM
65cuda
05/29/08 11:54 AM
05/29/08 04:50 AM
