Quote: You are supposed to put the new Mopar gasket on dry. I did, and it leaked live a sieve. I have an aluminum trans pan. Going to use "The Right Stuff" when I re-use it.
You probably have the same year(s) trans I do, check the front of the gasket with the contour of where it seals to the trans I bet they do not follow each other. Not sure if it's better to goop on sealant or just use a standard gasket.
