if trans fluid keeps pumping into the rad then that explains why the level never drops?
what exactly could have caused this and why would it make it run hot??
It is possible that the tranny fluid in the coolant is preventing the coolant from cooling properly but it could be another problem too.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
