(Piston + Pin + Locs + Ring Pack + Rod Small-End ) + 2x(Rod Big-End + Rod Bearing) + oil
Is this formula right ?!
Rod bearing 50
Rod big end 481
Rod small end 127
Piston 525
Wristpin 118
Rings 48
Locs 4
Oil 4
So I have a total Bobweight of 1888g right!?
When balancing a crank I have half of this weight in each side of each journal ? So I have 2 parts of 944g in each journal?
1-2g of tolerance is fine in final balancing?
