Good thread....
Question:
1) WHERE do you mount the fitting on the header ? ( is there a measurement to use,,certain distance down the header ? any tips/tricks/troubles/ people have had installing them)
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
The instructions i have say on the TOP surface of the header, just beyond the TRANSITION area.
2) NO MORE POP OFF BREATHERS ? ( this is what i have now,,Moroso sells a "screw" on type deal,,,would that be ok ? )
![](/ubbthreads/images/graemlins/scope.gif)
3) BAFFLES ? (just for the inside of the valve cover?)
![](/ubbthreads/images/graemlins/shruggy.gif)
4) HOSE TYPE (what are you guys using ?,,,is there a particular type recomended?)
![](/ubbthreads/images/graemlins/whistling.gif)
I have the motor out of the car,,,so the headers can be worked on,,,,
![](/ubbthreads/images/graemlins/sawzall-smiley.gif)
I have the Mr Gasket Evac kit ( sitting on the shelf ),,,
Might be a good time to install them....
thanks.
DOUG............
Moroso sells these,,,which i was thinking of getting,,,
Just noticed they are about $50 EACH !! (yikes) they are the screw in style,,, i have seen some other styles that look super nice,,billet,,etc,,,
