Wow...where's all the rest of the rod engines??
Here's one I got to cracking on last weekend.
Very cheap build. It's a 1984 318 from a diplomat.
We left the bottom end stock and inspected everything real good. Bearings looked great and the cylinders barely had any wear at all. Got a polished weiand intake for $75 from a member here and a $50 mopar '68 340 4speed cam (450/455 lift),
Then I put on a set of shaved 360 heads, will also feature a set of headers I got for free! Check out the vintage weiand valve covers I traded for. Other tidbits are a 600 holley and a double roller timing chain
Check out the air cleaner! Hubcap style
