I would agree with most of what was said other than I've seen mild 340's blow trannys and hurt people.If you are going to do any drag racing I would use at least a new bolt in sprague or the super sprague. then a billet steel front drum. You can also get low band apply valve bodies. Also only do second gear burn outs in the water box.
