http://images.google.com/imgres?imgurl=h...sa%3DN%26um%3D1
Power from the red wire on the back of the ammeter...
I realize this post is 4 years old but is it possible to post the pics again? I'm stuck with wiring for the fuse block on the convertible version 71 Cuda. I'm needing to add the terminals to the fuse block as it's non convertible fuse block.
Thank you,
Tom
