I used an internally regulated alternator to clean it up under the hood. The first feed wire off the alt goes to a power dist block under the hood that feeds relays for headlights and etc, I used the relay box from a 97 intrepid, its in the upper right hand corner of the picture below. A second wire off the alt feeds a power distribution block which is linked to the battery (in the trunk), this second block also powers up the fuse block under the dash. Power from the battery to the starter runs inside the car and is hot only in the cranking position and in turn there is only one wire on the starter.
