they need to be welded slow and with a nickle rod for cast iron
have not seen one hold up yet
but it was fun to break it,uslay going on and off the trailer,mud trucks and a few hooptees that was headed to the crusher
no way should you drive on the road with it IMO
if you need a locker,a mini spool is easy to do,a little cheaper and would hold up
if it junk you could try
