Greeting for the day!!
I just joined this lovely site. I found loads of useful information here. I would also like to contribute some thing for this community. I would like to share some quick weight loss tips. If you want to know how to lose 10 lb in a calendar week, you are believably not looking for a regular diet and workout plan. You can lose weight with a general diet and workout plan, However this requires a lot of time doing intense cardio exercises and following a strict diet. Here I will outline the perfect steps that I took to lose 10 pounds in just a workweek. 1. Keep Distance from all fried nutrients for the week 2. Drink In an 8oz glass of Citrus paradisi with breakfast every day. (this speeds up up your metabolism) 3. Take average portions (stop consuming when you are full) 4. Instead of consuming 3 big a meals a day, take 5-6 smaller meals to keep your metabolism up and keep your body burning fat. 5. Do not eat anything after 9pm. Calories do not burn, when you eat so late. 6. Proper sleep is necessary everyday.. Not getting adequate rest has been proved to be a ranking element to the body storing excess fat. 7. Apply a body/colon clean for the 7 days. This will get rid of unneeded weight stored close to the stomach area as well as cleanse your body of harmfull pollutants that cause you store fat and feel tired. Flush away excess pounds around the stomach area that otherwise would be hard to lose. 8. I advice you using Acai Berry Diet Pills. This one is proven to work, and you can get a free trial. 9. For those mens/womens who need to burn fat quickly, avoid alcoholic drink. 10. A low GI diet is an brilliant method of burning fat quickly.
Thanks!.!
Welcome to this forum. You should post non-mopar related posts in the General forum, otherwise you're going to pissoff the natives...
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
