I can't say for sure on the poly, but I've installed a 318 Magnum in the G/Friends 55 Desoto that had a 291 Hemi (gone) using the early Hemis motor mounts & brackets.
I had to modify the R/S mount bracket and add some metal to have a place to put one of the bolts. (the front lower one).
The L/S was a bolt on.
I had done a mock up with a late 60's 318 and the mounts bolted right on, but the Magnum engines have one of the 4 bosses machined off the block. (why I had to add metal to use the other boss).
R/S pic.
![](http://i471.photobucket.com/albums/rr72/SNK-EYZ/DesotoRSMnt.jpg)
L/S pic.
![](http://i471.photobucket.com/albums/rr72/SNK-EYZ/DesotoLSMnt.jpg)
There's a good chance it'll be a similar thing for you.
