Quote: '70 roadrunner convertible 383/4speed, 8/1969 build date Edelbrock aluminum intake with.....a HOLLEY. So, now do we throw away the book (again?) No A/C car for sure...and that's what came with the car. Early production with left over '69 parts? It's just too weird.
I'm surprised no one caught this ....
Did you take delivery of this car when it was NEW ??? There wasn't a 383 that rolled off the assembly line with an Edlebrock aluminum intake.
I'd like to see pictures of the choke pull off side of these holley carbs that were put on 69 mopars because an aftermarket holley vacuum secondary carb will not fit on a 68/69 383 or 440 intake without at least a 1/2" carb spacer , or at minimum the 3/8" fiber gasket, because the choke well is flush with the carb mounting surface.
