When using a windage tray on 440 I have used the 2 felt type gaskets that come with it....I have used silicone on every gasket, used 3m black adhesive to glue the first gasket to the block, and used permatorque sticky sealer-similar to gaskacinch...
I am just checking what you all do for torquing qualities and what type of sealers/cement/adhesives you use..I am looking for the best idea so that they dont leak..
I look at car shows and the most meticulous 440 engines still leak in the front corners of the oil pan gaskets near timing chain cover. 9 out of 10 cars leak in this spot....
thanks...Jeff...SKO VIKINGS THIS WEEKEND!!
