Quote: My 70 Challenger is a 10/69 build w/ optional Handling package. Came with Front sway bar, no rear sway bar and No dimples or holes.
I have a nice original rear sway bar set-up that I will be installing. I'm just trying to figure out the best way to install it and how to make sure the frame bracket holes are drilled in the right location.
Joe
Once you bolt it up, it will become appartent where the brackets go and get drilled. The bracketts are tapered I think which will limit where they go on the frame.
