I think with .003 clearance and full groove mains, I'd use the hv pump.
To keep hot oil pressure at idle "adequate" with full groove mains and increased bearing clearance you need more oil flow. I'm running one on a "B" engine with mains around .0025 and full groove bearings and get mid 20's hot oil pressure at idle. I wouldn't want less.
