Is there a way of knowing the effective results of a lighter bob weight, Example// A engine with a 1800g bob weight turns 7500 vs the same engine with a 1600g bob weight turns 8500/ before failure
Lighter weights free up RPMs.Before failure is is relative as to what fails.High RPMs will find the weak componants.Quality of parts and quality of machine work and assembly are more a determining factor at the bobweights mentioned.Check with the manufacture for any test data that supports their claims.For instance Oliver Rods has someone do distructive and non-distructive test on their various design of rods and well as metallergical studys on failed componants.
