Did you fab the door as well . My Haulmark doesn`t have one . Was wondering who you got the hardware from ?
Chryco
I found my generator door on ebay. It was less than a hundred bucks shipped with a buy it now price. Nice aluminum frame and fiberglass panel with a slide door/vent built right in. I can/t remember the nmae on it as it is out in the shop, but I can get the info tomorrow. Only thing it needs is the panel painted to match your trailer as they come in white. It is identical to the generator door on my brothers 2007 vintage trailer. Hope this helps, Beep
Did a little searching and found the info in my ebay account. The seller has an ebay store called Centralia Machine and the seller was 4ccenet. The listing was "24 x 36 polar white ventilated generator door with frame". In October they had 3 available. If you still need the manufacturer's name on the door, pm me and I'll get it for you. Beep
Thanks !
here it is .........
http://fiberoptictrailers.com/CM&FParts&AccessPage.htm
