Re: Rebuilding an AVS and wondering about mods.
[Re: JohnRR]
#578062
01/10/10 05:51 PM
01/10/10 05:51 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
On your bottom photo where the tip pf your pencil is pointing , those WERE the idle mixture screws , they are broken off because the steel screw is frozen in the cast alum body .
They are not broken off. Those are lead plugs. I can scratch it with my finger nail, and it matches the pics in the FSM. I couldn't find it because I was looking in the AVS section only, but at the very front of the chapter, it says to remove the plugs to adjust the screws, so that's what I will do. Not sure yet about the off idle adjuster, though.
