I can't speak for the Cudas but on the Challengers the verts use a different visor. It is not as wide (front to rear, so to speak) as the hardtop version.
It's the same issue with Cuda.
REM is one manufacturer of repro sun visors.
Legendary has started to make visors with correct OEM type material, but you have to send yours to them and they will use the cores
1970 Challenger R/T 383
1970 Challenger Convertible 383
