Quote: Great info guys. Thank you for all of the replies!
If mine breaks using an aluminum stator, I will report back in and let you guys know.
If it breaks, it will most likely be because it rolled a sprag. That's what usually breaks them. But since the sprags have become more reliable, it doesn't happen as often.
Since I use a spragless converter, I don't even worry about it.
