depends on if you want the factory look or very over restored look?these pieces are easy to detail yourself.
There's no such thing as "Over Restored", there's correctly restored and there's incorrectly restored, Jules hit's the "Correctly Restored" target closer than anything else I've seen.
Easy to detail yourself? Maybe if they are just dirty, but if the plating is bad or they are worn it's not a job for the average home DIY guy.
Now, let's see an example your work
