does a blown engine count?
my video is in my signature.i will get the printout.
this is a stock block 1968 440[.030 over]446,factory iron heads ported[2.14/1.81 valves]280/180 cfm at .600 lift blower roller cam
.646/.631 lift[1.5 aluminum roller rockers]
291/306 at .020 duration 112 lobe seperation.
eagle rods,wiseco 8.5cr blower piston,hellfire rings,aftermarket crank stock stroke.stock main caps,main studs/girdle 3/8,windage tray,milodon single line swinging pickup,melling HV pump,blowershop teflon stripped 8-71[10% OD]12 lbs of boost 2x850 holley carbs on race gas thru a A/W intercooler.
