Gotcha...I thought you were maybe removing a set that was already installed....my bad. As an FYI, the dowels are slightly oversize by a few thousanths to make a better press fit when using the standard type drill bit.
Good luck.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
