Re: '88 copcar 318 - piston, CR, etc - Magnum heads
[Re: alpha727]
#560659
12/23/09 05:52 PM
12/23/09 05:52 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
The flat tappet cams had a fuel eccentric and the roller cams didn't if you're running a mechanical fuel pump and you switch to a roller cam you'll need to swap to an electric fuel pump or get a special attachment that installs on the camshaft and allows the use of a mechanical fuel pump.
actually, the roller cams in M bodies have the long snout for a fuel pump eccentric....you could try find an M roller cam at a junkyard to regrind...or if you do a trade in/core (say, buy a hughes regrind), just specify one for a roller cam, or just buck up the $18 for this camshaft snout extender
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
Entire Thread
Fury Fan
12/23/09 04:26 PM
Rapid340
12/23/09 04:49 PM
Reggie
12/23/09 05:08 PM
patrick
12/23/09 06:22 PM
Fury Fan
12/23/09 07:20 PM
patrick
12/23/09 08:11 PM
alpha727
12/23/09 08:53 PM
patrick
12/23/09 09:52 PM
Reggie
12/23/09 10:54 PM
scratchnfotraction
12/24/09 03:26 PM
