I drilled and tapped a small hole in the water pump housing in line with the cam. Then installed a set screw and adjusted it to about .002 clearance between it and the front cover. I sealed the set screw with teflon pipe dope. I have about 2000 miles on it with no problems.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
