Personally, I think www.moparfins.com/forum has more info.
You would seeing as how your a moderator there, with essentially past and present members of the Dock.
That being said, '65 to '73 would be the only years its a C body, and if you don't want to fab motor mounts, you can always swap the sub frame...
