2002 Dodge Durango 4.7L.
On my list, this is close as I get. Anyone have better input on what this code is for?
P0388 Crankshaft Position Sensor Supply Too High CKP sensor voltage input above the maximum acceptable voltage.
P0401 EGR System Failure Required change in air/fuel ratio not detected during diagnostic test.
Thanks.
