I'd take a visual on the floors
if they look soild , just use a can of new undercoating ..freshen it up a little
Unless, you want to get real, real dirty
Cause its a thankless job
I removed it on my 71 and will never do it again. If its that hard to get off, its protecting and will protect the metal better than anything you will replace it with. My next car has it really thick and I intend to leave it and just recoat the areas that were missed the first time. As Bigdad says.
