66 Plymouth, Our Falcon is a little bigger than the Taurus, if your taurus is the same as the British one,
Falcon has been the Ford flag leader here since 1963, with Mustangs, Galaxies, and Fairlanes all being released in right steer over here in limited numbers.
No such thing as a locally released Big Block in any make however, although Chrysler did import and convert some Phoenixis with 383's in the 60's.
The latest Falcons are running Supercharged in-line 6 cyl which gets up and mambos, and there is a performance V8 option also.
