Do you have a 5 pin ECU and Mopar brain plug AKA the ECU pentastar connector and 4 terminal ballast? If not I'd get a replacement 4 pin ECU at your parts house & someone here has them for cheap and a used pentastar connector from a yard or if no time to go there order a new one (or a used one from here) & a 2 terminal ballast From MP & wire it up with the archives diagrams & you'll be up & running in no time.
