Get a good volt-Ohm meter and check the spark plug wires resistance. I have had a similar intermitent miss in high gear above 6000 RPM. It turned out to be the #4,6 and 8 spark plug wires
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
