With the B&M kit you get very good instructions and pictures. It comes with everything you need to do the changes including drill bits. If you read the instructions ans go step by step it pretty easy and will give you much better snappier shifts. If you do a quick online search for both brands of kits there will be instructions you can look at to see if you want to take on the job.
