I have a 66 Valiant that i am putting a 318 in.. I figured that while i have the slant 6 out i would replace the bushings and torsion bars.. anyway i realized i have the contol arm and spindles from a 74 duster with disc brakes, will these bolt on my car with 9" drums?? the control arms look the same, is the ball joint a different size? I already have an 8 3/4 with 11x2 1/2 in the rear but i figured its better to have more brakes than not enough.
1996 cummins diesel ext cab, long bed
1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph),
1974 Duster(360- 13.63@ 99.96 w/3.23 gears),
1933 Dodge DP (201)
