A true 7 degree negative pinion angle will usually bind.
I recommend 5 degrees, maximum.
Make the pinion parallel to the transmission as a baseline, then roll the pinion downward 4 degrees and weld the perches. This will yield a true 4 degree negative pinion angle.
no more than 5 degrees nose down regardless.
