Quote: I use 2 bolts and a piece of chain,one good pull and it comes right out.
Sometimes it takes me two or three pulls now You can take a short piece of chain and hook it under the two bolts (that are there to be used in removing the front pump, there half way up from the bottom bolts) and use a lever to pull it out by bracing it on the other side of the bellhousing
