Why would anyone want to switch to a roller with the same spec's?
I would just keep the flat tappet in that case.
Its hard to compare a flat tappet cam to a roller even if the spec's are close..They are totally diff. I always check V-P specs, and degree the cam each and every time one is installed no exceptions period.
But to answer your direct question relatively speaking "Yes".
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
