Captain, before you install that side glass check to make sure the curvature of the glass matches the original. I have found that some of the aftermarket glass is flatter that the originals. This causes the glass to bind up in the window channel. One fix to this is to file the plastic guides down to roughly half their thickness. This will it to slide in the channel a lot easier yet the glass still stays firmly in place.
