anybody else knowing 904's)do you know if the front seal on the 904 and the 727 are the same.
The shifter shaft seal is the same, not sure on the front pump seal
The front pump seal is NOT the same .
this trans is on the ground , the seal can be replaced without dropping the pan , carefully pull the seal , KD tools sells a tool to do it in the car and it would be easier with it out ogf the car even without the tool , and drive it back in with a deep socket ...
