It is accurate that the "up" command is not fast. (electric life) They have been in for about 5 years if I remember and they are reliable. I bought repro door panels and the switches fill the crank opening and look and work good there. Again, not fast going up as said, but reliable.
What about going down? The kit I put in actually broke the rubber stop. Although pricey the XV kit has the helper spring, like factory parts, just seems like a much better design.
