I would just replace the block.
Yep... Welding MAY work but unless its a numbers block to a rare car that sounds like scrap. Epoxy is unlikely to work due to thermal expansion of the block--HIGHLY likely to crack. You would constantly be looking for coolant in oil, until you found it of course.
