David, are you looking into your Mohave Green car?
For cars '67 and older, you can get an IBM card that is the Build record of the car from Chrysler historical. The card will have the VIN and the S.O. number on it. If you can locate the SO#'s on the body, the IBM card ties them together to prove the cars VIN.
The SO numbers can be hard to find. You need to have the rear bumper off and look near where the left bumper bracket mounts to the body. On the core support it is near the top left corner of the radiator. It could be on the front, back, or on top of the core support.
Chysler historical can be contacted at: pms@chrysler.com
Good luck!
Joel Nailed it! Here's where to look for the rear number
