On this page you will find all the products you need to do the job.The big eraser wheels work OK...but they can also heat and damage the polyester coating on the aluminum.The 3M wheels are for removing factory pinstripe on paint jobs...not polyester coated sheets.First use the vinyl remover...then adhesive remover....then wash the entire trailer with a 3 parts Dawn and one part Castrol Super Clean (12oz total) add to 5 gallons of water.Be quick to rinse it off ...usually works best with 2 people. This final wash SHOULD remove any ghosting left over from the decaled areas. GOOD LUCK...I've done 6 53' haulers...it sucks !!!!!!
http://www.signsupply.com/accessories/application_fluid.asp
