Quote: IS THERE A TUNNEL RAM INTAKE THAT BOLTS UP TO MAGNUM HEADS?? Sorry about the caps.
AFAIK the pattern is the same as any SB so I'd think a SB tunnel ram would fit.
Magnum intake bolts go straight up and down unlike the ones on an LA that go in almost straight into the intake face of the head. I -frequently re-drill the heads to use the LA intakes, the other way around looks sloppy.
